Advanced application availability monitoring with Squared Up
Join Matthew Long and Adam Kinniburgh as we take a deep dive on the new Application Availability Monitoring features in SquaredUp v4.
Enterprise Applications provide a new way of surfacing application health to your IT teams and wider organisation, by tying together the internal health of the application, it's dependencies, and the health of the app from an end user perspective. In this webinar, we'll show you how we at SquaredUp use the Availability monitoring feature of EAs to monitor squaredup.com and it's various subdomains. We start with a quick refresher on the intended availability monitoring use case, and then dig into what actually happens in SCOM when you configure monitoring from within the SquaredUp and save your Enterprise Application.
We then take a look at how you can use SCOM Overrides to tweak the behaviour, by extending our out of the box functionality or modifying test behaviour for specific apps or test locations. If you'd like to use the script to override web tests, check out the links below.
Finally, we look at a sample use case of using the Custom PowerShell test type to hook into a URL testing service like Pingdom and aggregate the results of it's test into a health state in SCOM.
Useful links
Sign up for the Coffee Break series
Coffee Break webinars run on the last Tuesday of every month and are bite-sized tutorials for SCOM and SquaredUp enthusiasts.
Sign up for the Coffee Break series here.
