This blog post is for anyone needing a jumpstart into the world of Kusto. (For those more advanced, look at using Kusto to aggregate and visualize data).
Perhaps you’ve heard about Kusto and are just curious. Maybe you’re just starting to use Azure Monitor for your application monitoring. Or maybe you're building your first SquaredUp dashboard with KQL.
Whatever your reason, set aside the next 10 minutes and we'll get you up to speed with KQL.
Ready? Let's go!
KQL stands for Kusto Query Language. It’s the language used to query the Azure log databases: Azure Monitor Logs, Azure Monitor Application Insights and others.
You won't be using Kusto databases for your ERP or CRM, but they’re perfect for massive amounts of streamed data like application logs.
Kusto was the original codename for the Azure Application Insights platform that Azure Monitor is now based on. If you're wondering where the name comes from, it's named after Jacques Cousteau – a French undersea explorer – and you’ll see some cheeky references to Jacques in the Kusto documentation.
It sure is! SQL, as you probably know, stands for Structured Query Language and is used to query traditional relational databases like Microsoft SQL Server.
The languages look similar too.
If you know what this line of SQL does:
SELECT * FROM ConferenceSessions WHERE conference = 'Ignite 2018'then you'll find KQL pretty easy to pick up.
Kusto databases do actually support SQL queries. But that just wouldn’t be as much fun as learning KQL...
OK, the SQL query above would look like this in KQL:
ConferenceSessions
| where conference == 'Ignite 2018'Aha! Microsoft aligning all products on a single language! Unfortunately not.
Although it looks similar, KQL isn't PowerShell. And it's not the M query language you use in PowerBI either. But that '|' character (called a pipe) is very much the same thing as in PowerShell: it passes (or 'pipes') the data through into the next command.
Using pipes makes it much easier to grasp what’s going on when you read a query, and it helps structure things when you're authoring a query.
So the query above takes all the rows in ConferenceSessions and pipes them through to the where statement, which filters to the rows where conference is 'Ignite 2018'.
You can chain multiple statements together by piping the data through to further statements:
ConferenceSessions
| order by session_titlePatience, young padawan.
For a start, you might have noticed that equality operators use double ==.
conference == 'Ignite 2018'But that’s not all.
Case-insensitive comparisons on strings use =~.
conference =~ 'ignite 2018'And string contains (case-insensitive) can be done with contains:
conference contains 'ignite'DateTimes are different and more powerful too. For example you can refer to d, h, m, and s for days, hours, minutes and seconds, and use them in queries:
starttime > now(-7d)You can see that KQL is quite expressive and there is a lot more to learn. Don’t worry, though, you’re well on your way to becoming a KQL Jedi!
If you're familiar with SQL or PowerShell, there are other similarities that you can use.
Let’s take a look at the KQL keywords count, project and extend. These are three very useful keywords you’ll use often.
You guessed right, the keyword count gives you the count of rows. It's like SUM in SQL and measure.Count() in PowerShell.
To use it, simply pipe your data into the count statement.
So this SQL:
SELECT SUM(*) FROM ConferenceSessionsOr this PowerShell:
Get-ConferenceSessions | measureBecomes this KQL:
ConferenceSessions
| countThe keyword project is like SELECT in SQL and select in PowerShell. It allows you to pick the columns (or properties) you're interested in.
Like with other keywords, you pipe the data into the project statement to select the columns.
So this SQL:
SELECT session_title, level FROM ConferenceSessionsOr this PowerShell:
Get-ConferenceSessions | select session_title, levelBecomes this KQL:
ConferenceSessions
| project session_title, levelIf you need to calculate columns, use extend. It adds new columns to your data.
ConferenceSessions
| extend duration_hours = duration / 60.0
| project session_title, level, duration_hoursThe KQL keyword sort by is straightforward to use. It's like ORDER BY in SQL and sort in PowerShell:
ConferenceSessions
| sort by starttimeIf you want to truncate your results, the keyword take is like TOP in SQL and select-first in PowerShell:
ConferenceSessions
| take 10Often, you'll want to combine sort by and take to give you the top N results. KQL has the top command especially for this:
ConferenceSessions
| top 10 by starttimeIt's also worth knowing that KQL commands have aliases (i.e. there can be more than one word for the same command). For example, the keywords top and limit do the same thing.
No surprises here. It's much the same as in SQL:
ConferenceSessions
| join ConferenceStats on sessionidThere are two commands that are absolutely essential if you’re exploring the data interactively: summarize and render.
The keyword summarize is closest to GROUP BY in SQL. It is typically used to count the number of rows in different categories. It works by grouping together rows using some comparison, and then performing an aggregation.
For example, if we want to count how many sessions are at each conference:
ConferenceSessions
| summarize count() by conferenceAnd the render keyword is a real 'wow!' command if you’re using a KQL client like Azure Data Explorer:
ConferenceSessions
| render piechartTa da!
Ah! I had been keeping this from you until now.
Azure Data Explorer is like a Jedi's lightsabre. It can do extraordinary things but only in the hands of someone who has the right powers.
After getting this far, you should have the right KQL powers!
https://dataexplorer.azure.com/clusters/help/databases/Samples
You can paste in any of the examples we’ve looked at so far and see them for real (apart from the join example).
Top tip: use shift-enter to execute a query.
The KQL client in the Azure portal is very similar to the Azure Data Explorer.
Try browsing to a Virtual Machine in the Azure portal and select Logs under the Monitoring section.
Then try the following KQL queries. These should be familiar to you now.
SecurityEvent
| countSecurityEvent
| take 1SecurityEvent
| summarize count() by ActivityPerf
| where ObjectName == "Processor"
| project TimeGenerated, CounterValue
| render timechartThese should get you started, but try out your own queries!
We also have a KQL guide on aggregating and visualizing data with Kusto. Learn how to use aggregation functions, visualize query results, put your data into context, and more!
As always, share your questions and tips on SquaredUp's Community Answers - let's join forces and achieve everything we could ever wish for!
Good luck, young KQL Jedi!
